Structured Text
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • Structured Text
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
RemoteConnect for the SCADAPack x70
SWC
Crewman SWC
Crewman
Posted: ‎2023-02-16 11:47 AM
1054
Structured Text
I am trying to create a function block to be able to write the Object Parameters in x70 (eg. H1_limit)
The problem I am running into is I bring the Object name in as string and then try to add what value I want to read and join them together. I get an error because VALUE is a real and TagVal is a string. Is there a way to have the ST recognize this tagVal as an object and read the Value I am trying to get. Below is the ST.
if TAG <>'' Then (*Tag = PIO_SP474_AI1*)
     tagVal := (CONCAT_STR(tag,'.H1_LIMIT'));
      VALUE := tagVal;
else
      Value := -999.9;
end_if;
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
vdsvds
Ensign vdsvds
Ensign
Posted: ‎2023-02-18 02:36 PM . Last Modified: ‎2023-07-08 06:49 PM
I've just recently started using the RemoteConnect software, so might be barking up the wrong tree, but from what I can see, if you need to specify the Object name via a string, then you might need to use the "OBJ_NameToID" function to get the ID, then you can use the returned ID into the "OBJ_WriteField" function to update the attribute of interest.
Good luck,
vds
