Support forum for Schneider Electric SCADA systems, radios and RTUs. From commissioning integration devices and software, to enhancing existing installations or troubleshooting.
Posted: 2022-01-26 07:10 AM
Hi
I created a function block and I want to use it in a program / section in structured text (ST)
The code of my function in the section is:
FB_Division_0 (Numerateur := A,
Denominateur := B,
Division => C);
I am looking for best and simple way to write this function in my section, like:
C := FB_Division_0(A,B)
But it gives me the Error E1064 call of non-function.
Can someone tell me please what I am doing wrong?
Thank you.
Posted: 2022-01-27 02:15 PM
The error message has it spot on:
You are trying to call something that is not a function, as though it were a function.
You have created a Derived Function Block. The Function Block may only have a single 'Output', but this doesn't matter, the format of a Function Block is such that it shouldn't be expected to 'return' a value that can be assigned like this.
So the way that you should probably be calling this is:
FB_Division_0(A,B);
C := FB_Division_0.Division;
I actually may even be wrong on the parameter passing, it's possible that you have to set the inputs individually, i.e.
FB_Division_0.Numerateur := A;
FB_Division_0.Denominateur := B;
FB_Division_0();
FB_Division_0(A,B);
FB_Division_0();
Posted: 2022-02-14 05:17 AM
Hi BevanWeiss
Yous solution works well
FB_Division_0(A,B);
Thanks for the answer.
