Support forum for Schneider Electric SCADA systems, radios and RTUs. From commissioning integration devices and software, to enhancing existing installations or troubleshooting.
Posted: 2024-01-14 08:53 PM
Dear experts,
I need download file for SCADAPack workbench and Econfigurator.
As per download advise from Schneider, the file available under SHA 256 Check sum, but when I click the file only pdf format available. Requesting experts advice to tackle the download issues.
Posted: 2024-01-15 02:46 PM . Last Modified: 2024-01-15 02:56 PM
Hello Abu,
It sounds like you are attempting to configure SCADAPack E type RTU's. Note that this is a separate download from the "Standard" or non-E type. This software is available on our Exchange Shop. Here's how to get it:
- Navigate to exchange.se.com
- Click Login/Register in the upper-right corner
- If you have an account, log in. If not, register on the system. It only takes a short time.
- Once logged in, search for SCADAPack E Workbench using the search bar
- Select SCADAPack E Workbench and Utilities from the search results
- Click the blue Download button in the upper right corner, then wait for the download to finish.
- Right-click on the zip file when it's downloaded, go to Properties and Unblock the file
- Right-click on the zip file again and select Extract All...
- The package includes an InstallationInstructions.pdf file. Follow these instructions carefully. It will walk you through the process of installing SCADAPack E Configurator and SCADAPack Workbench.
NOTE: The most important part of the instructions will begin on page 16, which is section 7.2. Make sure you follow these instructions carefully.
After you have downloaded software from our Exchange shop, you can later log in again and get the latest version. To do this, hover over Purchases and Downloads on the right side of the top menu, then select My Digital Library.
Hello Abu,
