SCADAPack 474 Modbus Register with initial value
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • SCADAPack 474 Modbus Register with initial value
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
TimKM
Crewman TimKM
Crewman
Posted: ‎2024-12-03 04:28 PM
1
847
I am new to remoteconnect and SCADAPack 474s, but I am familiar with ControlExpert. Is there a way to create a modbus remoteconnect variable that has an initial value?
Or is there a flag that is only set upon startup of a program - so that a move could be enabled only once - in order to set an initial value?
Thanks in advance
  • Logic
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
Joel_Weder
Captain
Posted: ‎2024-12-05 08:57 AM . Last Modified: ‎2024-12-05 09:37 AM
Hello Tim,
Logic Editor Elementary variables can be easily preset to initial values when writing an application:
  • Open the Elementary Variables data editor
  • Select a variable you want to assign an Initial Value
  • In that variable's Value column, type the desired initial value
  • After all initial values have been assigned, build the logic
  • Save the RemoteConnect app, then go Online and Write to the RTU
These initial values are saved and written to the RTU along with the application.
To write initial values on a power cycle or stop then restart of the logic, you could trigger Writes in logic to the desired variables when system bit %S13 goes true. It goes true only for the first scan of the MAST task.
Here's one way you can set up initial values for RemoteConnect objects:
  • Add the objects to be preset into an Object Browser created for that purpose.
    (It's easiest to place all objects you want to preset into one Browser)
  • In that browser, select an object to be configured
  • Click the Edit Entry button
  • Set the display format and the desired preset value
  • After configuring all desired objects with preset values, save the application
  • Go Online and Write the application to the SCADAPack
  • In the online browser created, click the Write All button
This presets desired values into all objects quickly. It can be repeated at multiple sites, as the preset values are saved along with the application.
Joel Weder
Remote Operations Specialist
Joel_Weder
Captain
Hello Tim,
Joel Weder
