SCADAPack 470i Edge application reflash
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • SCADAPack 470i Edge application reflash
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
SCADAPack™ 47x | 47xi
secres
Crewman secres
Crewman
Posted: ‎2025-02-17 01:46 AM
1224
I have a SCADAPack 470i and I am using the Edge application for some testing. During the tests, I overwrote the linux dynamic linker file \lib\ld-32.so. This had the effect that all the dynamically compiled files where not able to execute including ls, cp and others. Eventually I lost connection with ssh and I was not able to recover one since SSH does use that file.
I attempted to do a firmware update from RemoteConnect but its fails with code 43. This is expected since the firmware update runs an internal command in the linux system, which actually cannot run because it uses the ld-32.so to do dynamically linking for executing the update, which eventually fails since the file is broken.
My question is, is there any way to recover the situation before sending the device back? The RTU is working and is able to do operations but the Edge part is completely non functioning. Is there an alternative way to reflash the firmware for the Edge part? Is there any interface that could work for me to get access to the device like serial just for the Edge part?
Joel_Weder
Captain
Posted: ‎2025-02-18 07:53 AM . Last Modified: ‎2025-02-18 07:56 AM
1
1151
Hello Secres,
The Edge firmware is typically loaded thru RemoteConnect. To be clear, in case you've not done it correctly, here's the procedure:
- Go online with the RTU (not the Edge board) using RemoteConnect
- Right-click on the SCADAPack x70 Controller Settings -DeviceDTM in My Network
- Select Additional Functions, then Update Device Firmware or Bootloader.
- The first option available is to update the Edge firmware.
- Insert a USB stick containing the firmware into USB port 2 or 3.
- Edge firmware file can be found in a sub-folder of the RemoteConnect install folder. Typically this is:
C:\ > Program Files (x86) > Schneider Electric > RemoteConnect > Firmware > Edge
If that procedure still does not work for you, I suggest you contact our Global Tech Support team, explaining in detail what's happened. Here's their contact info:
SupportRO@se.com   or
1-888-226-6876
Joel Weder
Remote Operations Specialist
secres
Crewman secres
Crewman
Posted: ‎2025-02-28 08:56 AM
In response to Joel_Weder
Hi Joel,
Thanks for the hint. In the end the problem was resolved with a factory reset after an Edge SD card wiping. The first attempt to factory reset the device did not resolve the issue. After contacting SE support, seems like it was required to wipe out the SD card before the FR. After wiping the SD card of the Edge module and doing the FR process (button factory reset action + 90sec waiting), the Edge module was recovered. Seems like this was not expected as the Factory reset should wipe out the SD card.
Again thanks for the support
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2025-02-17 08:10 PM
I haven't actually played around with the SCADAPack47xi series.  During the initial discussion there was mention of being able to fully configure them just by using a USB dongle.
I don't know how far that actually got, but I would have expected USB firmware flash from bootloader would be in there (if nothing else).
Failing that, you could use the bootloader process to try to write in the firmware.  That shouldn't require any linux process to work.
I did give it a quick google, but unfortunately everything seems to point towards the 'pretty and fancy' RemoteConnect to do it.. without mentioning bootloader operation.  I'm pretty sure there was stuff in the user manual (at least from the SCADAPack 47x series) as to how to enter bootloader with a certain button push power cycle combo..
Joel_Weder
Captain
1
1152
Hello Secres,
SupportRO@se.com   or
1-888-226-6876
Joel Weder
secres
Crewman secres
Crewman
Hi Joel,
