Remote Connect, Changing a Physical AI Logic Variable Type.
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • Remote Connect, Changing a Physical AI Logic Variable Type.
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
RemoteConnect for the SCADAPack x70
SWC
Crewman SWC
Crewman
Posted: ‎2023-02-15 07:32 AM
877
I want to be able to set the Notifications in the X70 Logic for the physical AI, DI, AO and DO. In order to do this I need to change the Logic Variable type from its default. I will use AI as an Example.
So AI slot is a T_SPx70_DINT and I want to change it to T_SPx70_ADV_ANALOG.
Can I do this?
Is there any issues that will Arise?
thanks
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
Joel_Weder
Captain
Posted: ‎2023-02-15 08:11 AM
Hi SWC,
Changing an object's logic variable type to an advanced analog provides many more sub-parameters. This includes the alert notification settings and many other things, so can be very useful. The only potential down-side is that an advanced analog does use more memory in the controller. But the x70 RTU's have so much more memory space than older models it's not an issue unless you have many thousands of objects.
Joel Weder
Remote Operations Specialist
