Support forum for Schneider Electric SCADA systems, radios and RTUs. From commissioning integration devices and software, to enhancing existing installations or troubleshooting.
Posted: 2025-06-04 05:41 AM
I am having trouble opening projects in Vijeo. I recently downloaded Vijeo from the version 6.3 installation files, and in the designer it says I have version 6.3.0.103 (pictured). I am attempting to open files from my companies network drive but I am met with an error for project version mismatch (pictured). I have tried to download the file locally and open it from a local drive but was met with the same issue.
Is 6.3 not the latest version of Vijeo? It says the file was created in 6.0.0 and modified in 6.3.0 so I am confused as to why I cannot open the file. Could this be a licensing issue?
Thanks.
Posted: 2025-06-05 07:37 AM
Your installed version as you mentioned is 6.3.0.103 but the project was last modified using 6.3.0.1007
I suspect that this is what is causing the issue.
I did a search and it looks like the current release version is now 6.3.1 and it appears there is also a service pack available as well.
Link for 6.3.1: Vijeo Designer V6.3 Installation files | Schneider Electric
Link for SP1: Vijeo Designer V6.3 SP1 installion files | Schneider Electric
