Length of TBUM297138 cable?
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • Length of TBUM297138 cable?
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
SCADAPack 47x
Posted: ‎2021-11-24 06:38 AM
2413
A few searches for this has not brought an answer that I could find.
What is the length of the 20 pin to 16 pin adapter cable, TBUM297138?
TY
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
MartinChartrand
Captain MartinChartrand Captain
Captain
Posted: ‎2021-11-24 07:07 AM
2407
According to the shop drawing, it's between 2 and 2.5 inches. The range is likely due to the type of cable that is bent through two connectors. See attached.
Martin C.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Posted: ‎2021-11-24 07:20 AM
In response to MartinChartrand
2401
Thank You Martin.
Are there longer versions of this adapter cable available in case they need to jump down to a lower DIN rail to get to the expansion module?
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
MartinChartrand
Captain
Posted: ‎2021-11-24 07:51 AM
In response to Anonymous user
Hi again,
In this case you also need a TBUM297212 connector adapter (male-to-male) and then one of the normal 5000-Series Inter-module cables (IMC) suited to the length of your specific needs:
TBUM297269 Shielded intermodule cable, 12 inches (0.3m) long
TBUM297192 Shielded intermodule cable, 18 inches (0.45m) long
TBUM297193 Shielded intermodule cable, 24 inches (0.61m) long
TBUM297131 Shielded intermodule cable, 30 inches (0.76m) long
TBUM297162 Shielded intermodule cable, 45 inches (1.14m) long
TBUM297174 Shielded intermodule cable, 72 inches (1.82m) long
In Summary:
- SCADAPack 53xE or 47x or 57x RTU (with provided 20-pin IMC female connector)
to
- TBUM297138 Adapter cable (20-pin male to 16-pin female IMC)
to
- TBUM297212 IMC cable extension adapter for 5000-Series I/O modules (16-pin male to 16-pin male IMC)
to
- One of the six IMC cables listed above for 5000-Series I/O modules (16-pin female to 16-pin female IMC)
to
- A 5000-Series I/O module (16-pin male IMC)
Thanks!
Martin
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
