[Imported] Which location for a 900MHz yagi?
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • [Imported] Which location for a 900MHz yagi?
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
Trio Licensed Radios
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-05 01:00 PM
>>Message imported from previous forum - Category:Communications Products <<
User: mchartrand, originally posted: 2018-10-25 15:09:40 Id:219
_______
**_danw:
The existing 900MHz yagi is mounted up tight against a steel walled building. The graphic image is in the attachment, and shows a 'looking down' view. Low signal strength between the two points requires some remedial action. Radios are 1W FHSS ethernet radios.
My question is which is the best location to remount the antenna with a extended horizontal mast?
The location that places some of the steel wall behind the yagi or almost no steel behind the yagi?_**
_________________
kb4mdz:
Just joined the forum, and saw this question, which no one answered.
Really, I don't think it matters much. A Yagi has by its very nature a directional characteristic; signal is 'aimed' toward the narrow end. What is behind it (behind the longer, or reflector elements) has less effect.
What would be bad would be aiming the yagi parallel with the wall; and esp. close to it (within a couple wavelengths - at 900 MHz, a wavelength is about 12 inches. But that's now what you've diagrammed.
If you've installed, what has been your finding?
  • Radio
Replies 0
