[Imported] Wet Gas Calculation
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • [Imported] Wet Gas Calculation
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
Flow Measurements
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-10-25 02:40 PM
>>Message imported from previous forum - Category:Realflo Electronic Flow Measurement<<
User: mchartrand, originally posted: 2018-10-17 18:57:57 Id:86
**_bandi:
Can anyone advise on how to calculate wet gas used Realflo ? Thanks_**
____________________________
mchartrand:
We've added the parameter Wet Gas Meter Factor in RealFLO 6.01. Basically the user can find out what the water content for the gas is and then apply a factor to adjust the flow volumes accordingly. The excerpt form the user manual is :
** Wet Gas Meter Factor: This parameter is an adjustment to the volume, mass and energy values when there is water in the flow. Typically a test is conducted to determine the water content of the gas to be measured. The Wet Gas Meter Factor is applied to the volume, mass and energy values to get a corrected value. For example: if the water content is determined to be 5% then the meter factor is 0.95.
  • RTU
Replies 0
