[Imported] Stream ID Basic Functionality
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • [Imported] Stream ID Basic Functionality
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
Trio Licensed Radios
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-10-25 12:51 PM
>>Message imported from previous forum - Category:Trio Data Radios<<
User: joelw, originally posted: 2018-10-17 18:09:28 Id:64
**_jweder:_**
__________________
Stream ID's (SID's) can be used with the E, M and K Series radios to route a message from the Host to one specific Remote radio or group of Remotes. Messages going into a serial port at the Master radio will be assigned a specific Tx SID. This SID will stay with all packets sent via this port unless a Translate is done at a repeater location. In either case, the data packet will reach ALL radios which have the same SID on their Rx side. (only exception is where a repeater is set up to repeat only a limited range of SID's)
The only way to route one message so ONLY a specific RTU hears it, and the next to another specific RTU, would be to use more than one serial port. The E series have two ports for this reason. The second port can be configured to have a different Tx and Rx SID, and thus repeaters can route the packets differently.
  • Radio
Replies 0
