[Imported] ScadaPack350
Remote Operations Forum
Support forum for Schneider Electric SCADA systems, radios and RTUs. From commissioning integration devices and software, to enhancing existing installations or troubleshooting.
Send InviteCancel
Posted: 2019-10-2503:42 PM
>>Message imported from previous forum - Category:SCADAPack RTU<< User: mchartrand, originally posted: 2018-10-18 19:29:12 Id:131 This is a re-posting from the obsoleted (October 2018) "Schneider Electric Telemetry & SCADA" forum.
**_mikey: How do I assign the slave address of the unit to a register? Thank you._**
___________
du5tin: There is a serial configuration register assignment that does this. Check the Telepace or Isagraf Workbench help files for more info.
