[Imported] Realflo Flow Extension Units
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • [Imported] Realflo Flow Extension Units
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
Flow Measurements
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-10-25 01:16 PM
>>Message imported from previous forum - Category:Realflo Electronic Flow Measurement<<
User: mchartrand, originally posted: 2018-10-17 18:44:02 Id:78
**_texyank:
What are the engineering units used to calculate the Flow Extension for AGA 3 gas measurement. The meter is set up to use US units of measure, psi, inches of H2O. The flow extension is reported in kg/m3s.
Does the RTU do all calcs using bar and millibar?
Is there a way to have the flow extension reported using the configured units?_**
__________________
PSysak:
"What are the engineering units used to calculate the Flow Extension for AGA 3 gas measurement. The meter is set up to use US units of measure, psi, inches of H2O. The flow extension is reported in kg/m3s.
— Yes. It's a fixed unit in the RealFLO current readings view. RealFLO does do some conversion between the contract unit and kg/m3s.
— No.
— The current RealFLO version does not support that.
  • RTU
Replies 0
