[Imported] Read registers as float C++ tools
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • [Imported] Read registers as float C++ tools
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-10-26 02:13 AM
>>Message imported from previous forum - Category:SCADAPack RTU<<
User: mchartrand, originally posted: 2018-10-18 20:17:19 Id:140
**_brcgomezle:
Hi all,
I'm working on some program in which I need to read some float values stored in Telepace modbus addresses. I know I can use dbase(MODBUS, Register) to read a 16b register and store it as a Integer, but Is there a function to read directly from the database and obtain a 32b Float?_**
_________
bevanweiss:
I haven't worked in the Telepace environment, but it looks like what you might want is the databaseRead() instruction.
You could then have
_float f;
INT16* wordAddr = &f;
databaseRead( MODBUS, register1, wordAddr);
databaseRead( MODBUS, register2, wordAddr+1);_
That should populate the appropriate bits of the float as needed (assuming the float is 32bits).
You'd want to test the status of each databaseRead to make sure that they both occurred ok (returned true).
_____________
**_brcgomezle:
Thanks for your help, I'll try it._**
  • RTU
Replies 0
