[Imported] Isagraf Workbench
Remote Operations Forum
Support forum for Schneider Electric SCADA systems, radios and RTUs. From commissioning integration devices and software, to enhancing existing installations or troubleshooting.
Send InviteCancel
Posted: 2019-10-2601:22 AM
>>Message imported from previous forum - Category:SCADAPack RTU<< User: mchartrand, originally posted: 2018-10-18 20:14:01 Id:138 This is a re-posting from the obsoleted (October 2018) "Schneider Electric Telemetry & SCADA" forum.
**_dflag: I am currently working to replace an old RTU with Scadapack350 using Workbench for my program.I have four totalizer outputs which I mapped as modbus registers (floating points).I can read these registers in OPC but can not write to it.What Operand do you think I should use to write onto it._**
______________________
bevanweiss: A SCADAPack RTU does not talk OPC-DA (or HDA, or UA, or XML). So you're clearly missing details in the puzzle.
