[Imported] Help on AT Commands
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • [Imported] Help on AT Commands
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
Trio Licensed Radios
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-05 01:09 PM
>>Message imported from previous forum - Category:Communications Products <<
User: mchartrand, originally posted: 2018-10-25 15:58:31 Id:230
_______
**_jaydac12:
Greetings,
Just wanted to ask about AT commands. Is there a way to get the details about the last call made? like call duration and such. And if the call has ended. The modem does not send out response that the call has ended.
Thanks._**
_______
bevanweiss:
Here's a link to a basic AT command set reference
[http://michaelgellis.tripod.com/modem.html](http://michaelgellis.tripod.com/modem.html "http://michaelgellis.tripod.com/modem.html")
From that you will not see what you are after. So the answer is no, the standard widely supported AT command set will not give you this.
Now... like with all good standards, no manufacturer follows this precisely, so almost every device manufacturer will have their own proprietary AT commands also.. sometimes these are adopted by more people and they become their own standard of extensions.
Here's a version for GSM
[http://www.zeeman.de/wp-conten...cs-at-command-set.pdf](http://www.zeeman.de/wp-conten...cs-at-comma... "http://www.zeeman.de/wp-conten...cs-at-command-set.pdf")
If you advise what particular model of modem you're using, then someone might have more of an idea if that manufacturer has an AT command to access the call list.
  • Radio
Replies 0
