[Imported] Cybertec SMM-200 Replacement Paging Modem having issues
Remote Operations Forum
Support forum for Schneider Electric SCADA systems, radios and RTUs. From commissioning integration devices and software, to enhancing existing installations or troubleshooting.
Send InviteCancel
Posted: 2019-11-0501:05 PM
>>Message imported from previous forum - Category:Communications Products << User: mchartrand, originally posted: 2018-10-25 15:46:55 Id:224 This is a re-posting from the obsoleted (October 2018) "Schneider Electric Telemetry & SCADA" forum.
_______
**_PaulD: G'day, Looking to replace a existing SMS paging modem with a Cybertec SMM-200 and when connected to ClearSCADA having a SMS Pager Channel Error - GSM Modem poll failed. Any ideas? I am able to send SMS via AT commands in Hyperterminal and have the SMS Channel connection settings the same as those successfully usued in Hyperterminal. I am setting ATV1E0 in the modem command. Any help appreacited as I am already using these modems elsewhere and would prefer not to need to stock something different_**
_________
Dakshina: Hello PaulD,
Have you had any luck with the trouble?
I am also trying to use a cybertec 2220 modem with clearscada to send sms and having exactly the same issue.
Any help would be appreciated.
________________
**_PaulD: Dakshina, I wasn't ablt to get the Cybertec to work as expected so ended up using a Schneider SR02 MOD02 which worked straight out of the box. Apologies for taking so long to reply._**
