How to access the Citect Scada database?
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • How to access the Citect Scada database?
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
Mehak
Lieutenant Mehak
Lieutenant
Posted: ‎2022-02-15 09:50 PM
10468
Hello Everyone,
I want to ask how can I access the Citect SCADA database or How can I connect with SQL Server? I tried to connect but it didn't work for me. Kindly someone guides me?
Thank you
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
Replies 10
MartinChartrand
Captain MartinChartrand Captain
Captain
Posted: ‎2022-02-16 04:53 AM . Last Modified: ‎2022-10-19 01:06 AM
Hi @Mehak ,
Citect SCADA is not one of the products typically used by strict members of the Remote Operations (formerly SCADA & Telemetry) community so you might not get much help here. I would recommend contacting their support group directly.
There's also a Knowledge Base that contains Citect articles on Exchange that might have an answer for you:
https://community.se.com/t5/Industrial-Automation-Knowledge/tkb-p/industrial-automation-external-kb
However, you might also get lucky with one of experienced members here!
Martin Chartrand
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2022-02-16 06:03 PM
10434
You're going to have to provide FAR more information if you want any meaningful help.
What version of Citect SCADA do you have?
What methods have you actually tried to connect to it?
What made you think that this was an option at all?
I mean, I'd never think to try to connect SQL Server with my cat.. since my cat has never advertised any kind of SQL interface.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Mehak
Lieutenant Mehak
Lieutenant
Posted: ‎2022-02-16 08:31 PM
In response to BevanWeiss
10430
Hi @BevanWeiss,
I am using Vijeo Citect version 7.40. I am working on reports as customers demand whenever they want to generate the report, just press the button and generate the report with previous data. That's why I need to connect it with an SQL server to store my data in the database.
Thank you
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2022-02-17 03:59 AM
In response to Mehak
10424
Citect reports
https://www.youtube.com/watch?v=1ZAWxu9AuvY
Citect cicode SQL functions (for Citect to connect to an SQL server)
https://johnwiltshire.com/citect-help/Subsystems/CicodeReferenceCitectHTML/Content/SQL_Functions.htm...
You should use Citect reports.
Otherwise you'll need to find a way to either push data into your SQL server from Citect using the SQL functions I've linked you to, or to use Citect as an OPC server connected to Kepware Datalogger to write the data to an SQL database.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Mehak
Lieutenant Mehak
Lieutenant
Posted: ‎2022-02-18 03:30 AM
10417
Hi @BevanWeiss I do as you say to connect it with SQL using the following code
FUNCTION DATA_LOCK()
INT hsql;
INT hexec,i;
STRING Time_1;
STRING Date_1;
STRING Time_DATE;
STRING svar1,sVAR2,sVAR3,sVAR4,sVAR5;
hsql=SQLConnect("dsn=DATA_DB_REPORT")
Date_1=Date(2);
Time_1=Date(10);
Time_Date=Date_1+Time_1;
SQLSet(hsql,"INSERT INTO REPORT_TABLE(DateTime,Data1,Data2,Data3,Data4) VALUES('");
SQLAppend(hsql,Time_1+"','");
SQLAppend(hsql,RealToStr (one,12,2)+"','");
SQLAppend(hsql,RealToStr (two,12,2)+"','");
SQLAppend(hsql,RealToStr (three,12,2)+"','");
SQLAppend(hsql,RealToStr (four,12,2)+"')");
//SQLAppend(hsql,RealToStr (FF_LINE_1,12,2)+"','");
SQLExec(hsql,"");
SQLDisconnect(hsql);
END
But it is not logging the data into SQL as the connection is successfully established.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2022-02-20 02:22 PM
10397
Your code makes no sense:
'one' is not a valid REAL.
You haven't mentioned when you call this Cicode function, you haven't mentioned what the DATA_DB_REPORT dsn connects to or provided any evidence that any part of this was correct.
You should provide a screenshot of the query string as reported by Citect immediately before it's calling SQLExec.
You should also show the exact same thing from a 3rd party ODBC client when connecting using exactly the same DSN and when executing exactly the same SQL query that you have from your Citect (i.e. exactly the same string shown in the screenshot).
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Mehak
Lieutenant Mehak
Lieutenant
Posted: ‎2022-02-20 10:12 PM
10391
Hello @BevanWeiss,I am new to Citect SCADA Cicode. SQLAppend(hsql,RealToStr (one,12,2)+"','"); In this expression One is local variable that I defined and give datatype Real. I called the Cicode function in the button that I made in the graphic builder window. Below are the screenshots which show my ODBC connection is successfully established.
 sql connection.PNGodbc connection.PNGodbc connection_1.PNGodbc_connection_2.PNG
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2022-02-21 09:09 PM
10379
You haven't provided the query string as printed from the Cicode, nor a 3rd party ODBC client successfully executing that same query string from the Citect machine.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Mehak
Lieutenant Mehak
Lieutenant
Posted: ‎2022-02-21 09:45 PM . Last Modified: ‎2022-02-21 09:47 PM
10374
This is the query I passed in SQL.
3rd party ODBC client successfully executing that same query string from the Citect machine. I cannot understand this. Can you explain more?
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2022-02-22 02:09 PM
  1. Using SQL Management Studio is NOT a 3rd party ODBC client.  It's not even using ODBC.
  2. That is not the same query as you have shown you're trying to use in Citect.
  3. You have not shown the query string immediately before calling SqlExec in your Cicode (i.e. via message box or similar).
Perhaps you should engage an experienced contractor to perform this work for you.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
