Support forum for Schneider Electric SCADA systems, radios and RTUs. From commissioning integration devices and software, to enhancing existing installations or troubleshooting.
Posted: 2023-04-15 09:50 AM
I have been playing with this for 2 days. Have watched many Youtube videos, read much ScadaPack literature. Can anyone help me figure out how to simply map a physical address from the I/O listed in RemoteConnect config to a simple N.O. contact on a ladder rung? Is it really this difficult? Thanks.
Posted: 2023-04-17 08:25 AM . Last Modified: 2023-04-17 08:26 AM
First time doing this it can be a bit confusing, compared to the way things are done in Telepace or Workbench. But here's how to do it:
- On the Objects tab, select Object Configuration
- Expand the Digital group, find the desired input, then double-click on it to open it
(e.g. PIO_SP474_DI6 or whatever you might have renamed it)
- Ensure the Logic Type is Digital and the Logic Variable Type is T_SPx70_BOOL (should be the default)
- Close the object editor and open Logic Editor
- In the ladder diagram logic section, double-click on the contact to open the contact properties dialog
- Click the [...] "more" button which opens the Data Selection list.
- Ensure the "Inside Structure" box in the upper-right is checked to show all objects
- Scroll down to find your desired digital input object
- Click the [+] just to the left of the object name to expand its parameters list
- Select the .VALUE parameter, then click OK, and and you've done it
