Ask Me About Webinar: Data Center Assets - Modeling, Cooling, and CFD Simulation Join our 30-minute expert session on July 10, 2025 (9:00 AM & 5:00 PM CET), to explore Digital Twins, cooling simulations, and IT infrastructure modeling. Learn how to boost resiliency and plan power capacity effectively.Register now to secure your spot!
Send InviteCancel
Use the controlled automated work order process to propose changes to the non-power, rack-mountable equipment included in the racks for existing rooms (drag and drop).
Any changes proposed to the data center model will appear color coded and with symbols added to the equipment icons until the changes saved. After you have saved and closed the Work Order Editor, you can accept or reject the changes by right-clicking the equipment icon and selecting Cancel Planned Change or Execute Planned Change.
Note
You cannot delete or reposition a rack PDU or rack-mounted UPS when you are working in the controlled work order process as these are critical to the power connection setup for a server room. Instead, you can do changes of this kind when the Work Order Editor is closed.
