Equipment stages
Rack equipment planning
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA Change
  • Rack equipment planning
  • Equipment stages
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to Rack equipment planning
  • Mark as Read
Equipment stages
Picard EcoStruxureIT
‎2019-10-02 07:05 AM
When planning rack equipment, you can see equipment represented in various stages in the layout. The graphical representation varies slightly at different zoom levels.
Equipment Stage
Description
Existing
Equipment shown in its current location, with no action pending. It displays in dark gray, indicating that it occupies the position shown.
Pending Move (Source)
Equipment shown in its current location but has a move pending. It displays in blue with an arrow up, until you select to save, indicating that it occupies the position shown but that you can still edit it. After you have saved, the color will change to light gray, indicating that you can no longer edit it.
Pending Move (Destination) / Planned
Equipment shown in its target location for a pending move. It displays in green with an arrow down, until you select to save, indicating that the position is reserved, but that you can still edit it. After you have saved, the color will change to light gray, indicating that you can no longer edit it.
Pending Add
Equipment shown in its target location for a pending addition. It displays in green with a +, until you select to save, indicating that the position is reserved, but that you can still edit it. After you have saved, the color will change to light gray, indicating that you can no longer edit it.
Pending Deletion
Equipment shown in its current location, but with a pending deletion. It displays in green with an x in a circle, until you select to save, indicating that it occupies the position shown but that you can still edit it. After you have saved, the color will change to light gray, indicating that you can no longer edit it.
See also
Planning changes to rack equipment
Working with work orders
