Sepam 2000 ACE900 adapter
Protection & Control
Select a Country
  • EcoStruxure Power & Grid
  • Protection & Control
  • Sepam 2000 ACE900 adapter
Araceli_Monje
Araceli_Monje Mentor
74
JuanRayo
JuanRayo Mentor
41
Arun-kumar_PS
Arun-kumar_PS Mentor
33
Back to Protection & Control
Daniel_Sweden
Daniel_Sweden
Explorer
Posted: ‎2025-05-16 01:23 AM . Last Modified: ‎2025-05-16 01:24 AM
1666
I need to download the settings from a large number of Sepam 2000 protection relays. The manual describes using the ACE 900 adapter to connect to the relay. Does anyone know if this adapter is available somewhere or what it actually does? Is it just a simple rs232/rs485 adapter of some sort?
  • Sepam range
Replies 9
Araceli_Monje
Mentor
Posted: ‎2025-06-12 03:16 AM
@LaurentLemoine , can you please support with this request?, thx.
LaurentLemoine
LaurentLemoine Contributor
Contributor
Posted: ‎2025-06-12 05:09 AM
1575
Yes, the ACE900 adapter is necessary to establish an RS232 connection between a PC and the front panel of the SEPAM2000. It integrates both a signal converter and PC protection circuitry. However, it has been discontinued since 2015. We have one unit in our R&D department, which we preserve with great care.
Kareem
Kareem Contributor
Contributor
Posted: ‎2025-09-25 06:42 AM
Hi Laurent , is not there any possibility for re-manufacture
LaurentLemoine
Contributor
Posted: ‎2025-09-26 12:38 AM
1348
Hello Kareem,
I will check with R&D Team.
Best regards
Kareem
Kareem Contributor
Contributor
Posted: ‎2025-09-26 05:16 AM
Thanks alot , we still have much number of our legacy Sepam 2000 and we need at least to extract the logipam on the relays to merge to new models P7 for example .thanks in advance . is it also possible to use RS232 straight cable to do same function instead of ACE900 cable
LaurentLemoine
Contributor
Posted: ‎2025-09-29 01:32 AM
Hello Kareem,
Could you please let me know how many ACE900 converters you need?
R&D has managed to locate a very old file related to this product, but we’re still searching for the Gerber files.
I also need to check with Marketing — specifically with Elif Dede — regarding this.
Best regards,
Laurent
LaurentLemoine
Contributor
Posted: ‎2025-10-07 03:07 AM
1264
@elifhazandede Could you help to answer the question ?
Kareem
Kareem Contributor
Contributor
Posted: ‎2025-10-29 07:53 AM
i know it is hard to find but We might need 3 or 5 Kits , if possible . Thanks in advance
Araceli_Monje
Mentor
Posted: ‎2025-11-05 04:06 AM
@LaurentLemoine , was this topic solved?, thx
