Saitel DR - Redundancy with ISaGRAF V5.22 (hot-standby)?
Protection & Control
Send InviteCancel
2024-03-0101:00 PM
We are working on a project with Hot - Standby Saitel RTUs with isagraf for automation. I understand that
the Hot CPU is actively acquiring data with the field devices, while the Standby CPU gets its database updates from the active CPU via the redundancy link.
Can the internal variables defined in the isagraf program be transferred to the Standby RTU and the values of these variables retained if the Main CPU (i.e. Hot) fails and then switchover to the Standby CPU?
