SAITEL DP - maximum slave IEDs
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • SAITEL DP - maximum slave IEDs
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
Back to Protection & Control
milica_dukic_
Ensign milica_dukic_
Ensign
Posted: ‎2024-03-14 04:48 AM
758
Dear community,
I need an information what is the maximum number of slave IEDs which can be integrated in SAITEL DP?
Each IED has its own IP adress.
Also, these devices will be integrated in SAITEL DP over IEC104 Master protocol.
Are there any restricitons by number of IEC104 adresses?
Thanks in advance.
Best regards,
Milica Dukić
  • Saitel range
JuanRayo
Lt. Commander JuanRayo Lt. Commander
Lt. Commander
Posted: ‎2024-07-03 08:34 AM
Hello Milica.
When Saitel DP works as a IEC 104 master the maximum number of connections per each server is 4 as you can read in the document attached.
Regarding the restriction by number of address (Common Address of ASDU  value range: 0-65535)
