Sepam Error Code No.3
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • Sepam Error Code No.3
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
Back to Protection & Control
Ahmed-Salah07
Ahmed-Salah07
Cadet
Posted: ‎2024-04-27 07:16 AM
877
I've Sepam 87 for MV MOTOR  but suddenly I Lost all Temperature Signals and I found ERROR CODE NO.3 on Sepam and RTD Fault and also there is red led is on at the temperature module MET148-2. I just follow the manual instruction like:
1- Change the temperature module MET148-2
2- Change RG45
 I made all of this but the error still, but when I disconnect all RTD Sensor from MET148-2 the error is gone but of course RTD Fault still there and when I connect one RTD Also still no Problem
but when i add more than one the error come again
the attached photo from sepam when the error code is appeared
  • Sepam range
Gabriel_PHILIPPE
Ensign Gabriel_PHILIPPE Ensign
Ensign
Posted: ‎2024-07-04 01:16 AM
If you don't solve the issue, please could you contact your local customer care center here is the link https://www.se.com/ww/en/work/support/#Supportinyourcountry
Please add of your explanation the setting file extract of the Sepam and the SAV report. I put in attachment the SFT SAV software to extract the SAV report.
Best regards,
Gabriel
SFTSAV_6.0.0.0_User-ENG.zip
