SAITEL - redundant power supply
Protection & Control
Select a Country
  • EcoStruxure Power & Grid
  • Protection & Control
  • SAITEL - redundant power supply
Araceli_Monje
Araceli_Monje Mentor
74
JuanRayo
JuanRayo Mentor
39
Arun-kumar_PS
Arun-kumar_PS Mentor
33
Back to Protection & Control
milica_dukic_
milica_dukic_
Explorer
Posted: ‎2021-01-18 05:19 AM . Last Modified: ‎2023-05-30 10:09 PM
2521
Hello everyone,
In one SAITEL project, we need a redundant power supply. What we should know is whether there is a possibility to have different SM_PS40 on the same panel? For example, what we need is 110VDC as main and 230VAC as redundant backup power supply. Is it possible to have SM_PS40/A4 and SM_PS40/A5 on one SAITEL with one CPU module?
If we are correct, SM_PS40/A5 is module for 110/230VAC?
Thanks in advance.
  • Saitel range
Iván_González
Iván_González Mentor
Mentor
Posted: ‎2021-01-18 06:28 AM
4
2517
Hi @milica_dukic_
Your proposal is perfectly feasible. Saitel DP backplanes can host 2 power supplies, each powered from a different voltage source.
Replies 5
Iván_González
Mentor
4
2518
Hi @milica_dukic_
Amr_Hesham
Amr_Hesham Explorer
Explorer
Posted: ‎2021-01-19 04:27 AM
2509
Can I have redundant power supply for Saitel DR?
Tags (2)
  • Saitel DR
Iván_González
Mentor
Posted: ‎2021-01-19 05:46 AM
2505
Hi @Amr_Hesham!
Saitel DR does not support redundant supplies. For that type of requirement we can comply using Saitel DP.
Amr_Hesham
Amr_Hesham Explorer
Explorer
Posted: ‎2021-01-29 06:03 AM
Thanks @Iván_González
milica_dukic_
milica_dukic_
Explorer
Posted: ‎2021-01-31 11:23 PM
Thank you @Iván_González
