Change IP address IP for Micom P139
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • Change IP address IP for Micom P139
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
Back to Protection & Control
manhkhuong
Ensign manhkhuong
Ensign
Posted: ‎2021-01-21 03:51 AM . Last Modified: ‎2023-05-30 10:00 PM
1499
hi guys.
Anyone help me change Ip of IEC port Of Micom P139.
I used serial com to config.
Thank all of you.
  • Application cases
manhkhuong
Ensign manhkhuong
Ensign
Posted: ‎2021-01-26 12:42 AM
Thank eveyone.
I resolved this my problem.
Ivan_Puškaš_EC
Lieutenant Ivan_Puškaš_EC
Lieutenant
Posted: ‎2021-01-26 12:40 AM . Last Modified: ‎2021-01-26 12:41 AM
1488
I am guessing you are trying to configure IEC61850 protocol. IP address and all other setting you can configure in .mcl/cid file.
Simply add a new file MCL (for IEc61850 ed1.) or CID file (for IEC61850 ed2.)
After you open the file it will be opened in IED Configurator. Here you can configure all the parameters.
After you finish configuring the file, simply send it to relay. After this P139 will have IP address.
Best regards,
manhkhuong
Ensign manhkhuong
Ensign
Thank eveyone.
