SAITEL DP - IEC 61850 integration with Siemens SICAM PAS?
Protection & Control
Schneider Electric support forum about Protection Relays, Substation Controllers & RTUs, Arc Flash Devices & Systems in Medium Voltage and Low Voltage. A place to get support on product selection, installation, commissioning and troubleshooting.
  • EcoStruxure Power & Grid
  • Protection & Control
  • SAITEL DP - IEC 61850 integration with Siemens SICAM PAS?
Araceli_Monje
Araceli_Monje Mentor
74
JuanRayo
JuanRayo Mentor
38
Arun-kumar_PS
Arun-kumar_PS Mentor
33
Back to Protection & Control
dadasimoneto55
dadasimoneto55 Explorer
Explorer
Posted: ‎2024-07-11 09:29 AM . Last Modified: ‎2024-07-12 01:50 AM
4285
Has anyone done the integration between the SAITEL DP and the siemens SICAM PAS software using the 61850 protocol? When i try to import the .cid file from saitel I get error, even though the file has been validated by Schneider EPAS-E and Siemens system configurator.
  • Application cases
  • IEC61850
  • Saitel range
Tags (3)
  • IEC 68150
  • Saitel DP
JuanRayo
JuanRayo Mentor
Mentor
Posted: ‎2024-08-22 04:30 AM
Hello Jean-Yves.
For the benefit of any other interested on this topic I would say that eventually Sicam Pas supports only edition 1 of the norm for the scd file.
During the validation process of our scd file with Siemens software and based on a log message reported by them we had to:
1. remove "gi" from TrgOps because:
Log message:
2024-08-06 13:50:28 Warning: XERCES: Error at line 10427, char 85 --> '<TrgOps dchg="true" qchg="true" dupd="true" period="true" gi="true" />'
Info: (XERCES: 'Message: Attribute 'gi' is not declared for element 'TrgOps'')2.
2. we aIso removed that data class "SAV" after checking that was not relevant for our server side because this error message:.
2024-08-07 14:15:12 Warning: Common data class 'SAV' not supported.
2. We finally had to add one more Report Control Block instance for every dataset because another error message received not enough clear for me but clarified later by them.
Once we adapted our server side data model to these requirements they somehow validated the scd and sent me the final scd file in edition 2 (totally unexpected) so we finally integrated the file in our project to keep going with the project.
Customer First
Replies 7
JuanRayo
JuanRayo Mentor
Mentor
Posted: ‎2024-07-30 12:22 AM
1
4189
Hello. Sorry for delay but ... you know.....summer holidays .
Please share with us saitel Easergy Builder configuration and the cid file to be integrated within saitel.
dadasimoneto55
Explorer
Posted: ‎2024-08-16 08:04 AM
Thank you very much for your support in this case. Through your help and insistence we were able to move forward with testing this integration.
JuanRayo
JuanRayo Mentor
Mentor
Posted: ‎2024-08-18 11:24 PM
4127
Thanks for your reply.
We have had to adapt our saitel´s data model to the sicam pas need´s.
It was tricky but happy to know that you keep moving forward with your project.
BR
JYPOC
JYPOC Mentor
Mentor
Posted: ‎2024-08-20 12:07 AM
Hello @JuanRayo , could you please detail the solution here so that it can benefit others?
Thank you!
BR - Jean-Yves
JuanRayo
JuanRayo Mentor
Mentor
Hello Jean-Yves.
Log message:
Customer First
JYPOC
JYPOC Mentor
Mentor
Posted: ‎2024-08-27 02:01 AM
Great thanks, Juan Jo!
BR - Jean-Yves
Fernando_Ch
Fernando_Ch
Explorer
Posted: ‎2025-05-11 05:17 PM
Disculpa que versión de firmware en Saitel estabas trabajando? yo trabaje con la 11.06.14 y Easergy Builder 1.6.4, he trabajado con estas versiones y no he tenido problemas.
