P241 data model for Easergy Studio
Protection & Control
Select a Country
  • EcoStruxure Power & Grid
  • Protection & Control
  • P241 data model for Easergy Studio
Araceli_Monje
Araceli_Monje Mentor
60
Arun-kumar_PS
Arun-kumar_PS Mentor
26
JuanRayo
JuanRayo Mentor
24
Back to Protection & Control
Mathieu_Lansoy
Mathieu_Lansoy Mentor
Mentor
Posted: ‎2024-07-09 04:00 AM
1400
Dear Experts,
a customer is facing an issue to connect a P241 with Easergy Studio V9.3.6.
The error message says the data model file is not present.
The use of Data Model Manager does not help.
any idea on where to find the model ?
  Mathieu.
  • MiCOM range
HenriGRASSET
HenriGRASSET Champion
Champion
Posted: ‎2024-07-24 11:30 PM
Hello Mathieu,
What are the cortec and firmware references?
Regards
EDISON Expert
Tomasz_M
Tomasz_M Mentor
Mentor
Posted: ‎2024-08-01 12:28 AM
Hello Mathieu,
maybe try to check first if data model is really installed. It should be visible in the DMM. Apart of that probably quickest way is to go trough CCC with such questions.
Tomasz
HenriGRASSET
Champion
Hello Mathieu,
Regards
EDISON Expert
Tomasz_M
Tomasz_M Mentor
Mentor
Hello Mathieu,
Tomasz
Mathieu_Lansoy
Mentor
Posted: ‎2024-09-11 12:52 AM
Thanks for you answers.
They have used DMM with no success.
It finally turns out to be linked to the reference/cortec : most probably they have the modbus protocol, but not the "Courier" required by their use of Easergy Studio.
so that cortec code is one key, and CCC the other.
    Mathieu.
