Hello community,
Does anyone has a technical guide or explain the procedure to setup sampled values on MiCOM Px40 IEDs?
I would like to understand the settings from the point of view of the MiCOM IED and the MU.
Thanks in advance,
Manuel
For the Process Bus MiCOM Px40, we have competence centers. In your region South America, we have a competence center in Brazil that has People from Brazil, Chile, and Argentina.
The global Leader of the Process Bus Competence center is Henri Grasset. To summarize, we usually do not simply deliver a How to do Guide. When we have a PB Opportunity, we put a Competence Center member to follow it closely and even Henri when it is necessary. It has a lot of details that need to be considered.
That being said, for South America, you can contact Adenilson Santos, and he will put you in contact with a SAM Person. If you do not get support from them, you can talk to Henri. I'm a member of the competence center, but I'm currently in Spain, so if you didn't get support in the conventional chain, you can reach me out and I help you with that.
Best Regards
Best Regards
Thank you Andre. I will contact Adenilson, if I don´t get support I´ll let you know.
Best regards,
Manuel
