PowerLogic T300 - Where to find ATS GEN program (Auto-Transfer MV Source with standby Generator)?
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • PowerLogic T300 - Where to find ATS GEN program (Auto-Transfer MV Source with standby Generator)?
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
PowerLogic T300
Back to Protection & Control
Madridan12
Madridan12
Cadet
Posted: ‎2024-03-14 04:16 AM . Last Modified: ‎2024-07-09 04:19 AM
1474
I am beginning the configuration of the T300 and require the ATSGEN library.
Where can I download it?
Best regards.
  • Thumbnail of PowerLogic T300
    PowerLogic T300
View products (1)
  • PowerLogic T300
Tags (4)
  • ATS GEN
  • auto transfer source with generator
  • t300
jean-luc_batard
Lieutenant JG jean-luc_batard Lieutenant JG
Lieutenant JG
Posted: ‎2024-04-18 12:57 AM
Hello Madridan
You have actually 2 choices, hence Raj question
1/ Solution1 : use HU250 ATS native program and complete it with some formula according application note : ATS with firmware Easergy T300 - ATS with firmware.
This is the easiest way
2/ If you have extra needs not covered, look at other application note using an ISaGRAF program Easergy T300 - ATS with ISaGRAF programs
In both cases you will find necessary files in same folder to apply the application note
BR.
Jean-Luc BATARD
Distribution Automation Senior Application Engineer
Rajasekar_Chandrasekar
Ensign Rajasekar_Chandrasekar Ensign
Ensign
Posted: ‎2024-04-04 10:02 PM . Last Modified: ‎2024-04-04 10:02 PM
1402
Hello @Madridan12  Can you please tell me if you need embedded Logic of ATS GEN or ISAGRAF based?
Madridan12
Madridan12
Cadet
Posted: ‎2024-04-05 01:33 AM
1391
hello  @Rajasekar_Chandrasekar  i need the both library ATS GEN and ISAGRAF based?
jean-luc_batard
Lieutenant JG
Hello Madridan
BR.
Jean-Luc BATARD
