PowerLogic T300 - Operation error
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • PowerLogic T300 - Operation error
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
PowerLogic T300
Back to Protection & Control
Sasi123
Sasi123
Cadet
Posted: ‎2025-01-20 06:52 AM . Last Modified: ‎2025-01-21 11:37 PM
790
Hi Team,
I am facing this issue in T300 recently that I couldn't make local/remote operation of breaker open/close commands. It was working fine, but after sometime (No firmware update, no configuration update) it automatically not works.
I have totally 7 feeders controlling by 7 "SC150" and getting this issue only in 3 feeders(SC01,SC02,SC07). Remaining 4 feeders, I can locally close/open. And unable to do the same in these 3 feeders.
I can see "Main switchgear control failure" as "fault" in those 3 feeders only.
Kindly help me on this. Thanks in advance.
  • Thumbnail of PowerLogic T300
    PowerLogic T300
View products (1)
  • PowerLogic T300
JYPOC
Commander JYPOC Commander
Commander
Posted: ‎2025-01-21 11:41 PM . Last Modified: ‎2025-01-21 11:43 PM
Hello Sasi123,
1. When you have a control failure, you can check the reason of the failure (different numbers) in the event list: what do you have for these 3 modules? Please provide the event log.
2. Have you sent a request to global tech support ( global-na-tech-support@schneider-electric.com)? If not, please do so and add the event log.
Thank you
BR - Jean-Yves
TomBerry
Lieutenant JG TomBerry Lieutenant JG
Lieutenant JG
Posted: ‎2025-01-21 12:00 AM
From the screenshot it is clear that SC01 and SC02 received the commands and detected that the switch failed to operate. Look at the system logs from the SCs to check if there are additional messages before the timeout.
Different behaviour from different actuators can occur if the battery or power supply voltage is low.
JYPOC
Commander
Hello Sasi123,
Thank you
BR - Jean-Yves
