PowerLogic T300 - On SC150 module, how to use SF6 loss interlock to prevent MV switch operation?
Protection & Control
Send InviteCancel
2024-11-0604:07 AM
The SC150 module is used to control a motorized SF6 MV switch fitted with an auxiliary contact that will close in case of an SF6 loss (in a normal situation, this auxiliary switch is open).
How can I set the interlock in CoreDB to prevent the SC150 from operating (open or close) the MV switch in case of SF6 loss (auxiliary contact CLOSED), and only authorize it in case this auxiliary contact is OPEN?
