PowerLogic T300 - How to recover an IP address that has been lost or changed?
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • PowerLogic T300 - How to recover an IP address that has been lost or changed?
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
PowerLogic T300
Back to Protection & Control
John_Archer1
Ensign John_Archer1
Ensign
Posted: ‎2024-11-17 06:34 AM . Last Modified: ‎2025-01-24 12:36 AM
1320
hi guys it seems that there is something wrong with the T300 i am using. I can't access it at all, maybe the IP address has changed or something else is wrong. How to factory reset or reset. I searched for the IP address with IP Scanner and Wireshark and did not find it
its not ip 192.168.0.254
  • Thumbnail of PowerLogic T300
    PowerLogic T300
View products (1)
  • PowerLogic T300
  • Training
Rajasekar_Chandrasekar
Ensign Rajasekar_Chandrasekar Ensign
Ensign
Posted: ‎2024-12-10 10:41 PM
@John_Archer1  Please send a mail to global-na-tech-support@schneider-electric.com we can help you with factory reset
Mathieu_Lansoy
Lt. Commander Mathieu_Lansoy Lt. Commander
Lt. Commander
Posted: ‎2024-11-21 01:24 PM
On the T300, there is no reset possible if you can't connect to the product.
It is a security feature, to protect the majority of the installations, whereas a reset would be usefull in a limited number of cases.
If you can't access to the 'LAN' (default 192.168.0.254 or your setting) nor the WAN (default 192.168.1.10 or your setting) nor the Wifi, you can do nothing with the HU250. (same thing if you lose the passwords)
That said, the IP settings, and more generally the configuration, does normally not change spontaneously, and  it is important to understand (and share) what could be the cause of the problem (change in configuration, restart, any event ?)
We had for example people trying to set "white list" on both the LAN and WAN in the same time, thus loosing access to the product.
If something is potentially blocking the Ethernet communications, it is important to know.
Any context information around this problem is welcome.
Best regards,
   Mathieu.
John_Archer1
Ensign John_Archer1
Ensign
Posted: ‎2024-11-22 08:28 AM
Yes, I configured the Whitelist as you said, but I can no longer access it.How do I get back in touch now?
Ensign
