Hello, one of the products I use today, the P3U30 relay, has a fiber port. Can I connect it with a normal fiber ethernet converter or do I need to connect it with an industrial switch that supports IEC61850? If not necessary, can you share so I can make the necessary settings?
Hi @onur1 , it depends what do you want to do with the ethernet If IEC 61850 is to be used, then the switch must support IEC 61850 too.
BR
-juha-
BR
-juha-
