Micom P243 61850 Communication issue and Database Locked question
Protection & Control
Select a Country
  • EcoStruxure Power & Grid
  • Protection & Control
  • Micom P243 61850 Communication issue and Database Locked question
Araceli_Monje
Araceli_Monje Mentor
74
JuanRayo
JuanRayo Mentor
38
Arun-kumar_PS
Arun-kumar_PS Mentor
33
PowerLogic
Easergy MiCOM P24x
Back to Protection & Control
AsherHsu
AsherHsu
Explorer
Posted: ‎2025-03-11 04:50 AM
1211
Hello everyone,
I am an engineer from a Schneider Electric distributor in Taiwan, providing protection relay configuration, testing, and maintenance services.
I have encountered a communication issue with the Easergy P243 relay in a PRP (Parallel Redundancy Protocol) network. During characteristic testing using Omicron injection, with SCADA simultaneously receiving data from the relay, the IEC 61850 functionality of the P243 fails. In some cases, even third-party software like IED Scout cannot connect, although the relay still responds to ping requests. However, the P241 relay in the same network does not exhibit this issue, which I find puzzling. Has anyone experienced a similar problem?
Additionally, when the IEC 61850 function fails, I attempted to re-upload the CID file via the RS232 port and operate the switch bank function from the panel. The relay then displayed a "Database Locked" status. The only way to resolve this was by rebooting the relay. Could you clarify the possible causes of the "Database Locked" condition?
Attached are the configuration files and a recorded video of the "Database Locked" issue for reference.
Thank you for your insights.
  • Thumbnail of Easergy MiCOM P24x
    PowerLogic
    Easergy MiCOM P24x
View products (1)
Micom P243 Database Locked.zip
  • IEC61850
Arun-kumar_PS
Mentor
Posted: ‎2025-03-11 11:36 PM
Hello @AsherHsu
I am Arun from the MiCOM P40 Level 3 support team. I do not have an immediate answer to the issues you are facing. It must be investigated with all relevant files and traces.
I suggest you contact Schneider Electric technical support to investigate it.  Please use the below given link to contact the Taiwan support centre.
https://www.se.com/tw/zh/work/support/customer-care/contact-schneider-electric.jsp
Arun-kumar_PS
Mentor
Hello @AsherHsu
JuanRayo
JuanRayo Mentor
Mentor
Posted: ‎2025-04-24 02:17 AM
Could be many reasons for that behaviour, perhaps wireshark traces could help us to clarify.
One of the reasons could be a wrong use of the different instances of an indexed report. What I mean is every instance of a report should be used by only one client at a time so if you try to subscribe more than one to the same instance something bad happens.
I am just guessing, need more info like log files and wireshark traces of the entire pub/sub process.
