Continue
  • My Subscriptions
  • Events
P441 Relay Support
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • P441 Relay Support
Araceli_Monje
Araceli_Monje Mentor
74
JuanRayo
JuanRayo Mentor
41
Arun-kumar_PS
Arun-kumar_PS Mentor
33
Back to Protection & Control
manhkhuong
manhkhuong
Contributor
Posted: ‎2025-04-25 01:37 AM
1298
P441 Relay Support
Dear Guys.
My plant has used P441 Relay for 5 years.
Recently, after Protection function happen occer, Leds on Relay lighted up.
I want to reset these indication, however i can't login to relay by password: AAAA.
The procedures like below
- I typed AAAA and push Enter Button.
- LCD inform that Pasword Entered Access level 1. And after then turn back to tpye password page.
ANyone can help me.
Many thanks
  • MiCOM range
Arun-kumar_PS
Mentor
Posted: ‎2025-04-25 05:53 AM
1276
Hello @manhkhuong
It appears that the level 2 and level 3 passwords have been changed from the default "AAAA."
You will need at least level 2 access to reset the indication.
If you cannot recall or find the level 2 password, please contact SE technical support using the link below to create a support ticket. A support agent will assist you in obtaining the recovery password. You need supply details like relay model number, serial number, security code etc.
https://www.se.com/ww/en/work/support/country-selector/get-support.jsp Select country and then select "Contact Center".
Arun-kumar_PS
Mentor
1276
Hello @manhkhuong
manhkhuong
manhkhuong
Contributor
Posted: ‎2025-04-26 12:55 AM
Dear Sir
Thank for your support
Can I use easergy studio connect to relay and reset indication in my case
Many thank.
Arun-kumar_PS
Mentor
Posted: ‎2025-04-28 09:56 PM
Hello @manhkhuong
Yes, Studio has functionality to reset the indication. You can try it.
