Hello community,
I have some questions regarding MiCOM Px30 IEDs:
Beforehand, thank you for your time.
Manuel Trebilcock
Hi Manuel,
Rudolf
Hi Manuel,
For the question 2:
I have similar question regarding F-keys and disabling the password a while back. This is what I got from support:
"For this software version (671) login password is mandatory regardless of whether the relay has the cybersecurity option or not. Without entering the password, it is impossible to change parameters or send a command including F keys. As you know default password for all users is key combination: left right, up, down. The customer may change it in menu cell: Parameters / Config parameters / CS / Change pin code. However, the password cannot be reset (disabled). At least one character (arrow) have to be set.
After login, access to each function key depends of individual setting, that may be set in F_KEY: Password funct. key X, where X means number of the key. It may be changed only manually from the keypad on the front panel. Default value is "0" - no password, that corresponds to ENTER key."
I don't think that something has changed in newer versions.
Best regards,
Hi Manuel,
Rudolf
Hi Ivan,
Thank you very much for youe reply. It was really useful.
Best regards,
Manuel
