I can't read the circuit breaker value using the IEC-104 protocol with Double Point.
Protection & Control
Select a Country
  • EcoStruxure Power & Grid
  • Protection & Control
  • I can't read the circuit breaker value using the IEC-104 protocol with Double Point.
Araceli_Monje
Araceli_Monje Mentor
74
JuanRayo
JuanRayo Mentor
39
Arun-kumar_PS
Arun-kumar_PS Mentor
33
EcoStruxure™ Power Operation
Back to Protection & Control
Hoang_Phu
Hoang_Phu
Contributor
Posted: ‎2025-07-16 11:48 AM
803
Hello guys, I can't read Double point with IEC-104 protocol, how to configure it? At this address 100, the breaker is Open (1) and the breaker is closed (2), how to separate and understand it and read it. I can configure IEC-61850, please advise meTAG104.jpg
  • Thumbnail of EcoStruxure™ Power Operation
View products (1)
Araceli_Monje
Mentor
Posted: ‎2025-08-07 05:32 AM . Last Modified: ‎2025-08-07 05:33 AM
Hi @Hoang_Phu , if your question is related to Ecostruxure Power Operation, this offer is not part of the portfolio managed within this Protection &  Control Community, my apologies, could you please post your question in Ecostruxure Power Operation Community?
https://community.se.com/t5/EcoStruxure-Power-Grid/ct-p/power-management
Our colleagues there will be able to support you.
Araceli_Monje
Mentor
Hryhorenko_ActiVolt
Hryhorenko_ActiVolt
Explorer
Posted: ‎2025-10-06 03:54 AM . Last Modified: ‎2025-10-07 06:24 AM
Updated.
Try integer and your IOA seems off. In Driver Reference Help there is pretty much everything you need to know. but just in case, I<IOA> is a right structure for DPI adress, Anlo configure tag as Integer because digital displays 0 on 00 and 01 or 1 on 10 or 11, while integer converts value into 0, 1, 2 and 3 respectfully. But be aware that I haven't seen any component in TGML Editor that accepts values other than 0 and 1, you'll have to make your own component
