I am currently commissioning an Easergy P1V relay. The device trips the circuit breaker correctly when a phase is lost (undervoltage). However, after the fault is cleared and the phase is restored, the relay does not reclose the breaker automatically, even after a reset.
What I would like to achieve is:
When the fault is gone, the relay should send a “Close CB Order” after a defined delay (auto reclose).
The problem I am facing:
Sometimes the relay keeps sending open/close pulses continuously (oscillating).
Sometimes it trips the breaker but does not reclose it at all.
Questions:
1. Which exact menu/settings should be used for proper Auto Reclose configuration?
2. How can I avoid the “continuous open-close” loop?
3. Do I need to link the “Close CB Order” only with output relays, or also map “Protection Close” in the logic matrix?
Thank you for any advice or configuration examples.
Hello @Muh
This is little complex troubleshooting sort of case.
To better support you, I suggest you to create a technical support ticket.
Kindly contact our technical support team via the Schneider Electric web site:
đź”— https://www.se.com/ww/en/work/support/country-selector/get-support.jsp
