Join our "Ask Me About" community webinar on May 20th at 9 AM CET and 5 PM CET to explore cybersecurity and monitoring for Data Center and edge IT. Learn about market trends, cutting-edge technologies, and best practices from industry experts.
Register and secure your Critical IT infrastructure
Easergy T300 - cybersecurity and USB ports?
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • Easergy T300 - cybersecurity and USB ports?
Araceli_Monje
Lt. Commander Araceli_Monje Lt. Commander
22
HenriGRASSET
Captain HenriGRASSET Captain
14
Rudolf_Simon
Commander Rudolf_Simon Commander
13
PowerLogic T300
Back to Protection & Control
Windsor
Lt. Commander Windsor Lt. Commander
Lt. Commander
Posted: ‎2022-06-29 08:23 AM . Last Modified: ‎2023-05-30 09:57 PM
989
Can anyone suggest simple tests to prove to a customer that the USB and mini-USB ports on a HU250 head unit are actually disabled when the web server shows that they are?
Thanks in advance.
  • Thumbnail of PowerLogic T300
    PowerLogic T300
View products (1)
  • PowerLogic T300
Tags (4)
  • cybersecuriy
  • easergy t300
  • t300
Mathieu_Lansoy
Lt. Commander Mathieu_Lansoy Lt. Commander
Lt. Commander
Posted: ‎2022-07-04 02:22 AM . Last Modified: ‎2022-07-04 03:12 AM
984
These two ports have no associated user application anyway. So it is not easy to show they are deactivated.
Even more with T300 release 2.7, where the mini-usb is deactivated at low level, whatever the setting is...
One possible clue is the linux kernel log (/mnt/data/logs/messages.txt). It shows no reaction when the something is connected to the mini-usb (activated or not), and a limited reaction when something is detected on USB A (compared to when the port is "activated").
note 1: both USB A and Mini USB ports are now physically removed from the HU250.
note 2: these settings shall not appear on webapp in the next release.
JYPOC
Lt. Commander JYPOC Lt. Commander
Lt. Commander
Posted: ‎2022-07-04 03:28 AM
To complement Mathieu's response.
Since V2.7, these USB ports are not usable by anyone (including hackers) as there is no application behind.
To reflect this change:
  1. HU250 webserver will be corrected in the next release (USB ports visually removed)
  2. HU250 hardware will be modifed (USB ports physically removed)
BR - Jean-Yves
Tags (5)
  • cybersecurity
  • easergy t300
  • t300
  • USB ports
Mathieu_Lansoy
Lt. Commander
985
JYPOC
Lt. Commander
BR - Jean-Yves
Tags (5)
  • cybersecurity
  • easergy t300
  • t300
  • USB ports
This is a heading
