P3L30 with missing 87L function
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • P3L30 with missing 87L function
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
Back to Protection & Control
IMillican
Lieutenant | EcoXpert Master IMillican Lieutenant | EcoXpert Master
Posted: ‎2022-07-15 04:10 AM
2
1009
I have a P3L30 with the 87L function missing from the protection menu. From information on the SE website this may be hidden due to something else being missing. Please could someone suggest what the missing element might be, I've looked but can't spot it?
Ian
Reguram_A
Ensign Reguram_A Ensign
Ensign
Posted: ‎2022-07-21 07:26 PM
Hello @IMillican ,
Good day..!
You have to select ANSI 85 under COM1 port protocol in order to see 87L differential function in protection menu. I have attached the snapshot of COM1 port menu for your reference.
Best Regards,
Reguram A
Arun-kumar_PS
Commander
Posted: ‎2022-07-21 10:13 AM . Last Modified: ‎2022-07-21 10:14 AM
Hello @IMillican ,
Probably your device is not having differential communication card, please check optional card I details.
Arun
Reguram_A
Ensign
Hello @IMillican ,
Good day..!
Best Regards,
Reguram A
