Continue
  • My Subscriptions
  • Events
ANSI 87BB (High impedance busbar differential) in Powerlogic P5F30
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • ANSI 87BB (High impedance busbar differential) in Powerlogic P5F30
Araceli_Monje
Araceli_Monje Mentor
74
JuanRayo
JuanRayo Mentor
41
Arun-kumar_PS
Arun-kumar_PS Mentor
33
Back to Protection & Control
sungur
sungur Contributor
Contributor
Posted: ‎2025-02-11 12:49 AM
4267
Hello everyone,
In the manual section of Powerlogi P5F30 series relays, it appears that ANSI 87 BB (High impedance busbar differential) protection can be done.
Required conditions;
11. Only available with conventional (phase or neutral) CTs.
12. Function can be realized by application guidelines.
However, when the appropriate relay is selected, ANSI87 protection does not appear under the Protecton tab in the E-setup easergy Pro software.
How do we do 87BB (High impedance busbar differential) protection in the P5 relay?
  • PowerLogic P5
Arun-kumar_PS
Mentor
Posted: ‎2025-02-11 02:55 AM
Hello @sungur
Normally, a instantaneous overcurrent / earth fault element is used for high impedance protection
As described in the application note, Overcurrent element I>1 can be used for 87BB.
There is no specific 87BB element.
Arun
Arun-kumar_PS
Mentor
Hello @sungur
Arun
