send a direct closed command via fiber optic cable
Protection & Control
Send InviteCancel
2025-02-1209:08 PM
Hello guys, I am using P3L30 and SEL311L. Has anyone used this relay by connecting it with a fiber optic cable and sending a command to closed it? Is it possible to create a connection between the following two relays? help me
It is not recommended to connect two different manufacturers' line differential relays, either for teleprotection or control. Compatibility issues can arise due to differences in the data formats.
