Problem installing Ecostruxure PME 2022
Power Monitoring and Energy Automation NAM
This forum is created for the exchange of information and open dialogue regarding electrical power monitoring and energy automation products and services. Participants will have access to downloadable material as well as chat opportunities with subject matter experts.
  • Power Distribution NEMA
  • Power Monitoring and Energy Automation NAM
  • Problem installing Ecostruxure PME 2022
Charles_Murison
Picard Charles_Murison Picard
7
Michael_Neas
Ensign Michael_Neas Ensign
3
Robert_Lee
Admiral Robert_Lee Admiral
2
EcoStruxure™ Power Advisor
Back to Power Monitoring and Energy Automation NAM
Patricia_VZ
Patricia_VZ
Cadet
Posted: ‎2023-04-13 03:29 PM
2789
Installation of EcoStruxure software with a distributed architecture is required; However, it does not allow the installation to continue, it marks the version error in SQL
"Check 64 bit SQL Version"
If someone could help me find the origin of this error, it is being accessed with the credentials and permissions that are required and the version of Sql on the database server is correct.
  • Power Monitoring Expert (PME)
Charles_Murison
Posted: ‎2023-04-18 03:29 PM
2
2760
Hello @Patricia_VZ ,
The Check SQL Server Version Edition 64 bit, will, as the name suggests, check the SQL version. There is a list of supported versions the installer is checking against. If you version of SQL is not a supported version installer will fail.
list includes:
Standard Edition (64-bit) | Enterprise Edition (64-bit) | Data Center Edition (64-bit) | Express Edition with Advanced Services (64-bit) | Express Edition (64-bit) | Business Intelligence Edition (64-bit) | Enterprise Edition: Core-based Licensing (64-bit).
If you are able to connect to the SQL server with SQL Server Management Studio (SSMS) and run select @@version I believe this will let you know what version of SQL you have.
Charles
manhkhuong
Ensign manhkhuong
Ensign
Posted: ‎2025-03-01 01:13 AM
In response to Charles_Murison
1333
Dear Sir.
I have some error like below. Please help me
Many Thank
"END OF POST-DEPLOYMENT STAGE" was NOT found in C:\Program Files (x86)\Schneider Electric\Power Monitoring Expert\Database\Diagnostic\ION_Data.log
Request: CreateIONDatabasesWindowsAuth fail at function call: CheckFileForSuccess in broker: BrokerFragments\Database.Core.broker.xml
Charles_Murison
Posted: ‎2025-03-04 03:24 PM
In response to manhkhuong
Hello @manhkhuong ,
In the PMe installer, there are scripts to install the schema for the different databases. These scripts write to a log file. Some of the last lines in the log file indicate that script was successful. If the install does not see the last lines in the log file you get the message "END OF POST-DEPLOYMENT STAGE" was NOT found. Need to look into the log file to understand why.
Charles
