Posted: 2023-04-13 03:29 PM
Problem installing Ecostruxure PME 2022
Installation of EcoStruxure software with a distributed architecture is required; However, it does not allow the installation to continue, it marks the version error in SQL
"Check 64 bit SQL Version"
If someone could help me find the origin of this error, it is being accessed with the credentials and permissions that are required and the version of Sql on the database server is correct.
Power Monitoring Expert (PME)
- Tags:
- english
Posted: 2023-04-18 03:29 PM
Hello @Patricia_VZ ,
The Check SQL Server Version Edition 64 bit, will, as the name suggests, check the SQL version. There is a list of supported versions the installer is checking against. If you version of SQL is not a supported version installer will fail.
list includes:
Standard Edition (64-bit) | Enterprise Edition (64-bit) | Data Center Edition (64-bit) | Express Edition with Advanced Services (64-bit) | Express Edition (64-bit) | Business Intelligence Edition (64-bit) | Enterprise Edition: Core-based Licensing (64-bit).
If you are able to connect to the SQL server with SQL Server Management Studio (SSMS) and run select @@version I believe this will let you know what version of SQL you have.
Charles
Posted: 2025-03-01 01:13 AM
Dear Sir.
I have some error like below. Please help me
Many Thank
"END OF POST-DEPLOYMENT STAGE" was NOT found in C:\Program Files (x86)\Schneider Electric\Power Monitoring Expert\Database\Diagnostic\ION_Data.log
Request: CreateIONDatabasesWindowsAuth fail at function call: CheckFileForSuccess in broker: BrokerFragments\Database.Core.broker.xml
Posted: 2025-03-04 03:24 PM
Hello @manhkhuong ,
In the PMe installer, there are scripts to install the schema for the different databases. These scripts write to a log file. Some of the last lines in the log file indicate that script was successful. If the install does not see the last lines in the log file you get the message "END OF POST-DEPLOYMENT STAGE" was NOT found. Need to look into the log file to understand why.
Charles
