Ethernet IP connectivity issue with a PM5563RD meter
Power Monitoring and Energy Automation NAM
This forum is created for the exchange of information and open dialogue regarding electrical power monitoring and energy automation products and services. Participants will have access to downloadable material as well as chat opportunities with subject matter experts.
  • Power Distribution NEMA
  • Power Monitoring and Energy Automation NAM
  • Ethernet IP connectivity issue with a PM5563RD meter
Charles_Murison
Picard Charles_Murison Picard
7
Michael_Neas
Ensign Michael_Neas Ensign
3
Robert_Lee
Admiral Robert_Lee Admiral
2
Back to Power Monitoring and Energy Automation NAM
BrianW
Lieutenant | EcoXpert Master BrianW Lieutenant | EcoXpert Master
Posted: ‎2023-08-10 05:41 AM
1640
Just wondering if anyone can suggest a solution that I am seeing when trying to connect to a PM5563 meter?
I tried to connect to the meter using the default IP, but was not successful. I then tried to change the IP address on the front panel display, but noticed that the current IP and Subnet were sort of "grayed out" with exclamation points either side of the address text (see attached image). I was able to edit these and the meter saved them, but I cannot connect to the new IP address either.
Anyone any suggestions as to what might be causing the issue? The "grayed out" address are odd.
Brian
  • Entry Metering & Hardware
  • Medium Voltage (MV) Relays & Meters
Charles_Murison
Posted: ‎2023-08-16 10:08 AM
Hello @BrianW ,
Would strongly suggest you contact you local technical support (se.com -> support -> contact support) to start a case to troubleshoot this.
Charles
sesa29811
Crewman sesa29811 Crewman
Crewman
Posted: ‎2023-08-17 04:54 AM
Once you’re connected to the meter and your laptop is in the same network settings you will need to power cycle the meter leaving it connected to your laptop. If you notice both lights on solid on the meters port you will need to start a case with tech support
