3rd Party Modbus Meters
Power Monitoring and Energy Automation NAM
This forum is created for the exchange of information and open dialogue regarding electrical power monitoring and energy automation products and services. Participants will have access to downloadable material as well as chat opportunities with subject matter experts.
  • Power Distribution NEMA
  • Power Monitoring and Energy Automation NAM
  • 3rd Party Modbus Meters
Charles_Murison
Picard Charles_Murison Picard
7
Michael_Neas
Ensign Michael_Neas Ensign
3
Robert_Lee
Admiral Robert_Lee Admiral
2
Back to Power Monitoring and Energy Automation NAM
Chris_McVey
Lt. Commander Chris_McVey Lt. Commander
Lt. Commander
Posted: ‎2023-07-13 03:57 AM
2267
Trying to add a meter (Rayleigh Instruments  RI-D460) to PME system but this type of meter does not appear in drop down selections, can this still be added or would I need to change meters for PME compatible?
Chris
  • Power Monitoring Expert (PME)
Charles_Murison
Posted: ‎2023-08-15 02:48 PM
Hello @Chris_McVey ,
PME has a program called Device Type Editor (and device type installer). The editor is where you can build what the modbus mapping for the device would be. Modbus register XXX is for measurement YYYY, has ZZZ format, AAA/BBB/CCC scaling/ multiplier /offset.
This would create a .ion and .xml file. Once the files are created, you can use the Device Type Insatller to add the device driver to PME so device type can be selected in Mangement console. Can refer to Device type Editor (DTE) in PME's system guide.
Charles
Charles_Murison
Charles
ameezan
ameezan
Cadet
Posted: ‎2025-05-11 04:01 AM
1031
I have created a Modbus device using custom ION Handlers specifically to read the kWh parameter from multiple power meters. All parameters are communicating successfully with PME; however, the aggregated values (daily, weekly, and monthly) appear to be incorrect.
Could you please advise on how to resolve this issue?
Charles_Murison
Posted: ‎2025-05-13 01:03 PM
In response to ameezan
Hello @ameezan ,
Inside PME, data has information on how the data should get processed in different areas such as dashboards or reports. This meta data is likely what you need to edit to get aggregated data to display as desired. I suggest reaching out to your local technical support to get instructions on how to edit the metadata.
Charles
