ungrounded star system 4 wires
  • Power Distribution IEC
  • ungrounded star system 4 wires
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
zezo
Crewman zezo
Crewman
Posted: ‎2025-08-18 09:38 PM
677
for 11/.4kv transformer the lv is ungrounded star what is the effect of first line to ground fault on the ....?
1- 3 phase load (motor).
2- single phase line to neutral loads on healthy phases?
3- single phase line to neutral loads on faulted phase?
 by another way what is the effect of fault on  1, 2 , 3 and motor loads according to attached pic?
  • India Power Distribution & Digital
  • Knowledge
  • Medium Voltage
  • Operations & Services
  • Power Availability
  • Power Standards & Regulations
  • Safety - People Safety
Romain_Polette
Kirk Romain_Polette Kirk
Kirk
Posted: ‎2025-09-15 06:59 AM . Last Modified: ‎2025-09-15 07:00 AM
Hello @zezo ,
Because you are in ungrouded system, any first ground fault will not impact your process and operator security. On insulated network, earth leakage current cannot loop through ground to the MV/LV transformer (Iground will be very low).
In case of a 2nd ground fault on another phase, there is a risk (for peoples and processes). You need to install:
  1. an Insulation Monitoring Device at transformer side. This device will alert you when there is any first insulation fault somewhere on your electrical distribution. A maintenance operation is needed to find the defect quickly as possible. A fault locator can help you to find the fault more precisely.
  2. Residual Current Device to protect electrical installation, loads and peoples in case of second ground fault on another phase.
For you reference:
  • Please have a glance on the enclosed document (old but gold)
  • https://www.electrical-installation.org/enwiki/IT_system_-_Principle
  • https://www.se.com/in/en/faqs/FA279411/
  • https://community.se.com/t5/Power-Distribution-and-Digital/Vigilohm-Ins-Monitoring-Why-use-an-ungrou...
  • https://community.se.com/t5/Metering-Power-Quality/Vigilohm-Your-Essential-Assets/m-p/235012
  • https://community.se.com/t5/Power-Distribution-and-Digital/IMD-IM400-calculate/m-p/409010
Romain POLETTE
Solution Architect - France Operations
Manon_Chaboud
Commander Manon_Chaboud Commander
Commander
Posted: ‎2025-09-01 12:01 AM
Hello @zezo, thank you for your post, we'll come back to you!
Romain_Polette
Kirk
Hello @zezo ,
For you reference:
Romain POLETTE
