reboot via front panel menu
  • Power Distribution IEC
  • reboot via front panel menu
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
FergTF
FergTF
Cadet
Posted: ‎2024-11-15 08:48 AM
676
hello
Our PDU gui has crashed and so needs a reboot, ofc the web menu to reboot is not available.
Is the front panel menu option
RFCode > RFCode-Console -Disabled - Press "Select" WILL REBOOT
the same as "Reboot Management Interface" ?
  • Software
Manon_Chaboud
Commander Manon_Chaboud Commander
Commander
Posted: ‎2024-12-13 04:53 AM
Hello @FergTF,
The option you mentioned on the front panel menu, RFCode > RFCode-Console -Disabled - Press "Select" WILL REBOOT, typically refers to rebooting the device itself, which may include the management interface depending on the specific system architecture.
However, "Reboot Management Interface" usually implies a more specific action focused solely on the management interface without rebooting the entire device.
To clarify:
  • RFCode > RFCode-Console -Disabled - Press "Select" WILL REBOOT: This action likely performs a full reboot of the PDU, including any management interfaces.
  • Reboot Management Interface: This action typically reboots just the management interface without affecting other functionalities.
FergTF
FergTF
Cadet
Posted: ‎2024-11-18 08:30 AM
It was the same.
Manon_Chaboud
Commander
Posted: ‎2024-11-27 01:33 AM
Hello @FergTF, thank you for your question, we'll come back to you!
Manon_Chaboud
Commander
Hello @FergTF,
To clarify:
